Mon Jun 06, 2016 3:16 pm
Hi steelies,
I had a pickup by Ronnie Bennett installed on my steel and although I liked it I wanted to try out the original super sustain which incidentally I do prefer as it has a more pedal steel sound. The previous owner wanted more of a single coil telecaster sound apparently. So, I took that out and put the super sustain back on and it sounds a lot better but it now has ALOT of hum! I guess I must have wired it incorrectly as although it has always suffered with this it wasn't unbearable!
i play through a fender blues junior amp but that didn't seem to matter before I rewired the pickup. The pickup only has two wires coming out of it, one black one white. How can I earth this? The hum goes away somewhat when I am touching the strings but more so when touching the changer.
Any help would be much appreciated.
I can post pictures if needs be
Thanks
Phil
Mon Jun 06, 2016 5:19 pm
This won't eliminate your noise but it will help...
This was on a classic !
- Attachments
Mon Jun 06, 2016 8:32 pm
Great thanks!
Where is this grey wire coming from? I only have this set up. I have a tone and volume pot but I just rewired it how it was with the single coil, no idea if that was correct or not :/
Mon Jun 06, 2016 8:35 pm
Here is a close up
- Attachments
Tue Jun 07, 2016 12:25 am
The earth side of your wiring! White should be hot so I assume black will be the one!
Tue Jun 07, 2016 5:12 am
Haha ok, so leave the white one where it is and solder the black one to the underside of the changer like in your picture?
