Fri Oct 31, 2014 6:21 pm
I just got a Bennett pedal steel guitar yesterday , I changed the strings now the B lever does nt bend the G# on the 6th string properly , the 3rd string bends ok . The 6th bends a little and I cant see any movement on the bridge , any help gratefully received as Im completely clueless on all things PSG .
cheers
Sat Nov 01, 2014 5:47 am
You have probably put a wound string on the 6th, instead of a plain. Try a .022 plain string
Sat Nov 01, 2014 11:33 am
I agree. Stick a plain .022 on and tweek the nylon tuner if necessary to achieve the raise. Check for anything loose on that rod underneath too if it still fails.
Sat Nov 01, 2014 11:41 am
Thanks very much , Ive got a wound 24 on it at the moment I will promptly change it, once again many thanks,
Sat Nov 01, 2014 12:41 pm
I could nt get a plain 022 but a plain 020 is doing the trick , so I have nt broken it after all , phew .cheers
