Patching help please
Wed Dec 08, 2010 12:40 pm
I have a Peavey 112 and would like a few suggestions on how to patch a delay unit in? I have had a couple of suggestions but cannot get the response from the effect unit that I expected. Any suggestions please.
Re: Patching help please
Wed Dec 08, 2010 12:55 pm
Roy
You don't elaborate on the 'response' problem that you have. Quite simply, you patch your effects send from the amp into the input of the delay unit, and patch from the unit's output into the return socket on the amp. You are probably doing this already. If you go to http://www.peavey.com/assets/literature/manuals/nashville112.pdf and then go to page 5 it explains this in more detail, and tells you how to avoid distortion.
One of the problems with patching in a delay unit via send and return, is that you have no control over the delay repeats. By plugging the guitar into the delay unit and from there into your volume pedal, you can cut off the delays when you want to by use of the VP.
Hope this makes sense. I expect Basil will jump in here and explain things more comprehensively than I have, but that is the normal way of patching in an effect.
Wed Dec 08, 2010 2:18 pm
i take it you are talking about a delay pedal roy? or rack mount, there are four ways to my knowledge, and it wouldnt take too long to try them all, and see what works best for you,
1...... put the delay between guitar and volume pedal
2......put the delay between the volume pedal and the amp
3......patch the unit into power amp in, pre amp out, on the back of the amp
4......patch the unit into the post eq patch, send and return on the front of the amp
Wed Dec 08, 2010 9:53 pm
Thanks Ken, Yes that was one of the items I noticed I had no control of the repeat control.
Wed Dec 08, 2010 9:55 pm
Thank you Eddie.
Thu Dec 09, 2010 3:21 am
Thu Dec 09, 2010 5:36 am
I always put the delay pedal after the volume pedal.
Roy,
If you have a passive volume pedal, ie just a pot with no fancy electronics, try this:
Take a cord straight from the steel into the amp input (if the pickup is 'hot' on a GFI, use the low gain input).
Take a cord from pre eq patch 'send' (on the front panel) to the input of the volume pedal.
Take a cord from the output of the volume pedal to the input of the delay unit.
Take a cord from the output of the delay unit to the pre eq patch 'return'
Thu Dec 09, 2010 12:12 pm
Thank you everyone that's very helpful :D
Thu Dec 09, 2010 6:53 pm
Uncle Roy wrote:Thank you everyone that's very helpful :D
"Spose it's a good thing I never put my theories in then ! Hey Ho ! :D :lol: :guitar:
Frank. Corfu
Fri Dec 10, 2010 10:31 am
would just like to thank basil for posting that video, im now in two minds to either practice like hell 24/7 for the next 100 years, or throw the bloody steel into the river Moy, and become a drummer, even worse, become a singer
