Peavey 130 mod
Peavey 130 mod
Postby john roche » Sat Mar 05, 2011 12:19 pm
RS corby are selling the chips to mod a peavey 130 for £3.04 each , you will need 4 .
the chip number is OPA2134PA . stock number is 285-8069
john roche
Re: Peavey 130 mod
Postby zbplayer » Sat Mar 05, 2011 1:48 pm
They are the same chips for the Nashville 112,except you need 5. I got 5 x Burr Brown ones from the US for my NV 112. Came to about £12 with posting. Easy mod to do. Regards Graham
zbplayer
Re: Peavey 130 mod
Postby john roche » Sat Mar 05, 2011 2:31 pm
john roche
Re: Peavey 130 mod
Postby Phil Caine » Sat Mar 05, 2011 8:17 pm
Hi John
As a recent convert to the 130 I find it a great amp. Can you tell me the benefits of the mod?
Regards
Phil
Phil Caine
Re: Peavey 130 mod
Postby john roche » Sat Mar 05, 2011 9:03 pm
It takes some of the honk out of the mid range, also they a a better quality chip much quiter..I have not fitted mine yet due to spine operation
john roche
Re: Peavey 130 mod
Postby Phil Caine » Sat Mar 05, 2011 10:14 pm
Thanks John
For a few quid its got to be worth it. Is it an easy job?
Regards
Phil
Phil Caine
Re: Peavey 130 mod
Postby john roche » Sun Mar 06, 2011 10:36 am
It's easy to fit, remove the amp from the cab , look for 4 chips on the circuit board. make a note of the little notch on the chips , remove the chips with a small
screwdriver and replace with the new ones matching the notch
john roche
Re: Peavey 130 mod
Postby Phil Caine » Sun Mar 06, 2011 9:06 pm
Thanks John
I will definitely give it a go.
Phil
Phil Caine
Re: Peavey 130 mod
Postby SHAKEY » Mon Mar 07, 2011 4:44 pm
One thing you have to be careful about is if you do change them you may suffer from very loud speaker popping when you switch on or off. When I had my very first 130 I changed the 4558's for 0PA2604's and I got bad popping. Buggered the speaker. It seems the better quality the chip is the worse the POP.
Dave.
SHAKEY
Re: Peavey 130 mod
Postby john roche » Mon Mar 07, 2011 7:47 pm
I modded my nashville without any popping, I will let you know when I mod my 130 if all is ok..
john roche
Return to News
