Peavey Black Widow 1203 8 OHMS
Fri Feb 03, 2023 9:13 pm
If you want to give your Peavey Nashville 112 a new lease of life, this is the speaker to do the job.
Model 1203, 8 ohms. Shipped in its original box. £100.00 + shipping.
Re: Peavey Black Widow 1203 8 OHMS
Thu Apr 27, 2023 11:42 am
I’m not an expert on amp circuitry, but my Nashville 112 is 4 Ohm. What are the full ramifications of connecting an 8 Ohm speaker?
Thu Apr 27, 2023 12:43 pm
Thu Apr 27, 2023 1:08 pm
Great speaker Ted, surprised it's still available.
Olimpianative,
Yes it can be used. The Ohms rating stated on an amplifier is generally the minimum, not maximum. The 4 Ohm amplifier will have no problem powering it. :)
Note that if the power rating of an amplifier is rated at x Watts at 4 Ohms, the maximum output at 8 Ohms can be as little x/2 or ½ the rated output at 4 Ohms. As Ohms go up, maximum SPL (sound pressure level or volume) goes down.
This also delineates the problem of an amplifier driving a lower Ohm load: as the Ohms go down, the amplifier tries to deliver MORE power, likely more power than it’s circuitry is rated to handle. Hope that helps.
Thu Apr 27, 2023 3:18 pm
Thanks for your impput Jim .... seems you are pretty knowledgeable on the subject. I fitted a 12" BW 1203 in my NV 112
and the difference was amazing. Sarah Jory borrowed it last year when she was in Ireland doing a few gigs and she loved it.
Ken Byng, did you run out of words?
Thu Apr 27, 2023 7:46 pm
Ted Nesbitt wrote:Ken Byng, did you run out of words?
Unlike me Ted :lol:
I just wanted to make the point that all of the Peavey Nashville 112 amps that I've looked at have contained 8 ohm Blue Marvel speakers as standard, including 2 that I own. Your B/W speaker will be fairly close to a JBL D120 in tone, but way more robust. I have put a couple of Eminence Travis Toy speakers in my 112 amps, but if I was 50 years younger I would snatch your arm off for that speaker. As an old b*****d I need to reduce the weight of my amps these days, not increase them. :roll:
Thu Apr 27, 2023 8:36 pm
Ken, its awhile since we corresponded, I sent you a PM
Fri Apr 28, 2023 5:18 pm
Ted Nesbitt wrote:Ken, its awhile since we corresponded, I sent you a PM
Hi Ted
I have responded mate.
Ken
